Disc Conversion help PLZ!!!
Old Sep 3, 2011 | 03:43 PM
cjackson3396's Avatar
Question Disc Conversion help PLZ!!!
I recently aquired a 71 Swinger....buttload of parts came with it along with about everything I need to complete a disc brake conversion up front. My question is what all will i need...Things I have: Everything from a 73 dart. A-arms, spindles, along with rotors calipers, front brake lines...I think Im going to need the brake booster and new master cylnder too? Please any information would be greatly appreciated I have never done this before..
PS: also came with the new matching upper and lower ball joints
Old Sep 3, 2011 | 04:11 PM
DartcustomcrusieR's Avatar
What brakes do you have now? If you have 10" drums you can keep your existing upper control arms. If not you'll need upper control arms from a '73 and newer A-body. The spindles can come from a '73-'74 E-body, a '73-'76 A-body or any F-M-J body car like a Diplomat, LeBaron, 5th Ave, Volare or Aspen. No trucks or vans need apply.
but give us a list of things you have so we know where you are
Old Sep 3, 2011 | 05:07 PM
I have the a-arms from a 73 dart...spindles from a 73 dart..rotors calipers from a 73 dart...thats where I am at..I have already switched spindles and a-arms so what I am worried about is If i need the booster or not and what All i need for that part of the job brake pedal and whatnot..and When I mocked it up today when I turned sharply to the right the driversaide caliper hits the sway arm...any ideas? When i looked at conversion kits they dont include anything to fix or change that issue?
Old Sep 3, 2011 | 05:10 PM
I switched a-arms neways because the guy sent rebuilt a-arms
Old Sep 3, 2011 | 05:20 PM
Cazbah362's Avatar
Brakes
Jackson,
Just complete this setup on my 71 Demon. Things I learned:
Ball Joint pickle and heat: One of mine stuck, lots of heat and pounding (insert dirty joke here)
Lower ball joints, not sure but I had to get new ones - something about the diameter was smaller on the 71's vs 73-76.
Mine was non-power assist, so I did get a new master cylinder. Also, I opted top go with the large bolt pattern, so this may be the reason why I needed lower ball joints. and hoses, the area that it hooks to on the frame needed a bit of grinding to get them to seat, but did it.
And brake fluid and a helper, saved time, especially after a long day playing mechanic - which I am not. There was link from a guy named charlie on this site that had a link to another site outlining the ins-outs of this, wasa good help.
Good luck and let us know how it goes.
I just got done putting in my large bolt pattern 8 3/4, its beer time.
Old Sep 3, 2011 | 05:25 PM
Thanks Cazbah362, I will see if i can find that site...Yea When I bought the car it came with new ball joints upper and lower for the conversion so I changed everything. Thing that has me weirded is the caliper hitting the sway arm.. When I looked up the 73 arm to the 71 they are different but I would think the conversion kits they sell would include something to deal with that but so far everytime I look at a kit they just have the same stuff I have listed already.
Old Sep 3, 2011 | 09:26 PM
You may need the 73 lower arms & sway bar . I did a simillar conversion and had to do without the new sway bar I bought before the conversion on a 67 Coronet due to interference. I did not
add the power brakes on mine due to the HP cam I was using
Old Sep 4, 2011 | 07:51 AM
thanks....im not sure what I need at this point...If i need the sway bar and lower arms i gunna have to search a bit lol
Old Sep 8, 2011 | 06:38 PM
scotts74birds's Avatar
Does this help? http://www.moparaction.com/tech/archive/disc-main.html
heminate
Aug 18, 2019 03:06 PM
Hollonator
Mar 2, 2010 11:20 AM
Rbaisch
Dec 1, 2008 02:17 AM
mahd
Nov 8, 2008 09:55 PM
BTKBraden
Feb 22, 2007 11:31 AM
