Mopar Forums (/forums/)
-   Chassis, Suspension, and Brakes (https://moparforums.com/forums/f83/)
-   -   Lowering car. (https://moparforums.com/forums/f83/lowering-car-14114/)
Shrug Jan 23, 2013 07:53 AM
Lowering car.
OK I have a 1966 Dart 270 wagon.
What is the easiest way to lower it a few inches?
Thanks!
Skwerly Jan 23, 2013 09:59 AM
Torsion bar front end?
Shrug Jan 25, 2013 11:49 AM
Uhm... I actually have no idea. I have never been any good with suspension :(
How do I tell?
Skwerly Jan 26, 2013 10:56 AM
Does it have springs? Google '66 Dart front suspension and look at some pics. If it's torsion, it's easy as pie.
TVLynn Jan 26, 2013 01:05 PM
All A bodies have torsion bars. You can lower it some Maybe two inches. The suspension will have a tendency to bottom out. PUT the car up on jacks to adjust them. Any more than that and you need to have custom spindles made
Chryco Psycho Jan 27, 2013 11:35 AM
First soak the adjusters in penetrating oil , Make Sure the weight is off when you loosen the adjuster bolts so they do not strip & the cars falls on you , count the number of turns you undo each side so you get it even , your toe in will change as it is lowered so you Have to reset that as a minimum or have the wheels re-aligned .
The rear can be lowered with lowering blocks between the spring & diff , check the pinion angle , you can correct that also with angled lowering blocks if it is off .
Skwerly Jan 27, 2013 12:01 PM
Yessir! You can effectively lower your car in two hours this way. I had the back of my Fury down three inches via blocks, but I knew nothing of how to drop my front. Then someone told me about the torsion screws and about an hour later, the car was in the weeds.
:hello:
Shrug Feb 2, 2013 07:04 PM
I appreciate the info. After I finish the heads this week, I will crawl underneath and look around!
Thecollector Feb 19, 2013 04:28 PM
that is interesting to know how easy it is to lower the front. Would you need to re align the car after that though?
does any company sell lowering blocks specific for a body cars? or is it a make your own type deal?
mikerp76 Feb 19, 2013 05:10 PM
autozone carries them. yes you will have to get the front realigned for both toe and camber.
Thecollector Feb 19, 2013 05:19 PM
Nice, that is good to know thanks, Looks like once i have mine running ill be lowering it soon after, id be intrested to see some pictures of before and after from the OP, i know i will be snapping a few!:hello:
mikerp76 Feb 19, 2013 05:55 PM
i would also think about putting a small section of tubing at the back of the k frame near the oil pan just to make sure that the pan is protected from bottoming out on the road.
Thecollector Feb 19, 2013 09:00 PM
very good idea! thanks for the idea. id hate to have to buy a new oil pan :doh:
mikerp76 Feb 20, 2013 05:39 AM
i'm thinking of doing that on my car the pan sits about 1/4" below the k frame. and the bottom of the pan has a few dings in it already.
Thecollector Feb 20, 2013 08:55 AM
you lowered yours alredy or is that with stock hight? I'm in Maine land of potholes and frost heaves so lowered cars are not very common.
mikerp76 Feb 20, 2013 05:48 PM
it's semi stock height. it was lower than it is now when i first got it. and it bottomed out everytime i went over a speed bump
