67 fury 3 "click click click" sound
Old Sep 13, 2012 | 05:09 PM
ahrkar's Avatar
Hello, I have 67 fury III when i start her up i have click click click sound and starts sometimes. But recently it doesn't start at all. I've put new battery, alternator, regulator except starter. It might b the problem? if i have to take it out do i have to go through alternator belts and stuff???
Old Sep 13, 2012 | 06:02 PM
mikerp76's Avatar
what size engine do you have? and yes it sounds like your sarter gave up on you simple test you can try is to tap not pound on the starter with a hammer. if it starts then the brushes are sticking and it is due either replacement or a rebuild.
Old Sep 13, 2012 | 06:38 PM
Silverick's Avatar
Starter's bad. Those are the signs. Replace the starter and you should be good!
Old Sep 13, 2012 | 07:02 PM
ahrkar's Avatar
Thanks again guys
Old Sep 13, 2012 | 08:03 PM
mikerp76's Avatar
no problem.
ahrkar
Sep 18, 2012 10:27 AM
ahrkar
Jun 11, 2012 09:28 PM
1 Bad Mirada
Sep 14, 2010 01:12 PM
mystarcollectorcar.com
Apr 16, 2010 03:42 AM
Yorkie Mama
Apr 7, 2008 11:33 AM
