69 RR Windshield Wiper Motor ........................
Old Sep 17, 2023 | 10:02 AM
Miami69RR's Avatar
Hi Everyone out there in MOPAR Land!
Quick question ............... how difficult is it to replace the windshield wiper motor on a 69 RR? Any "how to videos" out there that show the procedure? Thanks in advance for any and all responses!
Tom
Miami, FL
Old Sep 17, 2023 | 02:34 PM
Kuvasz101's Avatar
I couldn't find a video. I'll go by memory from way back in time when I worked on them.
1. Disconnect battery cable first
2. Under the dash for most and I'm sure yours, you need to remove the nut from the wiper that connects to the motor arm.
3. Remove the wiper wires under the hood.
4. Remove the nuts holding the motor down. I believe 3 nuts and you should be holding it in your hand.
Old Sep 18, 2023 | 06:02 AM
Miami69RR's Avatar
Thank you and that's what I figured which I was hoping was not the case! I was hoping just removing the three bolts and disconnecting from the fire wall would to the trick! I don't know how I can get behind the dashboard. Can you just reach up there and undo the nut that secures it, or is it a big too do having to remove other components to get up behind there? Thanks!
Tom
Old Sep 18, 2023 | 10:45 AM
Kuvasz101's Avatar
Yes you could reach up and undo it. The defroster ducts may be in the way but no big deal. If you're up for it. Remove the 3 nuts on the motor and pull it up with one hand. It should expose the nut enough so you could remove the nut that attaches the wiper arm to the motor. If it won't pop upwards enough plan A goes into effect. Video gives an idea of what I'm saying
TerRoy
Feb 11, 2022 07:14 AM
RAPOM
Feb 3, 2021 03:10 AM
Desperota 488
Jul 20, 2013 11:21 AM
JP67
Feb 9, 2011 06:38 PM
siliconcrunch
Jan 4, 2008 11:22 PM
