After Market Gauge Install 63, 64, 65
Old Dec 16, 2021 | 03:29 PM
Donovan Frasure's Avatar
Hello all,
I will try to be as Technical as possible.
I have Two questions.
First I have a 1963 Dodge Dart: 1964 Plymouth Valiant: 1965 Dodge Dart.
All three should be the same answer.
I'm Wanting to Replace Factory gauges and Build my own Dash to Put the 7000 Equus gauges in them.
My 2 questions are as fallows.
1: Going from the Factory ALT Gauge to the New Alt Gauge I've seen the ALT gauge Delete Info to death. Can I Tie The Red Wire and Black wire On One Side of the New Gauge Positive and Ground to Ground? Please See Included Simple Diagrams.
Would I Need to add a 20, 30, 40, ECT Amp breaker for Load? Example Tie Red to one side of breaker and Black to other side of Breaker and the black side to Positive of New Gauge?
2: Does any one Know the Size of the Factory Speedometer Gauge Threads? New Gauge is 5/8 by 18 Thread size 0.104 Female Drive Cable. If I need an Adapter for the New Speedometer where would I look for one?
Thank you for any Help
Donovan Frasure
Ok so that is More then 2 questions.
Last edited by Donovan Frasure; Dec 17, 2021 at 02:20 AM. Reason: Adding New Simple Diagram
Old Dec 17, 2021 | 02:23 AM
Breaker Diagram
This is the Example of the Breaker Diagram I was thinking about. I hope It's clear.
Thank you,
Donovan Frasure
My72D100
Feb 28, 2019 05:33 AM
04 Diesel
Jun 11, 2013 06:16 PM
BruceJ
Oct 15, 2011 10:44 AM
1971superbee
Apr 10, 2011 07:32 PM
sgp7679
Mar 18, 2009 11:05 PM
