B body headlight issues
Old Jul 11, 2013 | 05:46 PM
haswdspa40's Avatar
Hello.....
I have a 1974 Roadrunner. Four headlights (of course). When the low beams are on, only the right low beam is lit. When the high beams are kicked on, the other three lights come on, and the right low beam goes out. Any suggestions on where to start? Ground? Where? Thanks for any suggestions, Dan
Old Jul 11, 2013 | 07:26 PM
I don't think you can plug them in wrong. CHeck the headlights make sure the low beams are both on the right side. After that I would check the dimmer switch/ headlight switch connections to start
Old Jul 11, 2013 | 09:41 PM
haswdspa40's Avatar
Thanks
Thanks, I will start there.....Dan
Old Jul 12, 2013 | 06:37 PM
mikerp76's Avatar
how many connectors are on the back of the low beam bulb. could be that the high beam filament burned out on one side and the low on the other.
Old Jul 12, 2013 | 08:12 PM
haswdspa40's Avatar
headlights....
Mikerp.....
The low beam has two prongs, the high beam three. So far I have cleaned the ground on the headlight harness....I am going to check the switches per TVLynn next......
Old Jul 12, 2013 | 08:18 PM
Originally Posted by haswdspa40
Mikerp.....
Other way around. Low beam has three
The high beams (2 prong) go in the inner buckets. The low beams actually have two filaments, low and high,
So in low beam, only the low beam filaments in the outer buckets are lit
When you change from low to high, the low filaments go OUT, and all 4 high filaments in all four lamps turn ON
This sounds like a poor ground on the failing lamp.
SXPKDuster
Oct 8, 2014 09:15 PM
THE GOOSE
Sep 28, 2010 05:36 PM
69SatSport
May 27, 2009 09:05 PM
stazja01
Jan 15, 2009 08:36 PM
raffaplymouth
Jan 20, 2007 01:24 PM
