Dash guage issues
Old Nov 13, 2019 | 12:15 PM
Coronet's Avatar
Dash guage issues
Does anyone out there know how to bench test tachometer of 1966 charger? Help needed.
Old Nov 14, 2019 | 08:49 AM
One of the best/most agreed with answers I could find out there in net land:
It's nearly impossible. For one thing, it takes a variable frequency source and that source will have fairly hostile voltages present. Not easy at all to simulate even with a frequency generator. About the only thing I can think of is to use a distributor machine and connect the tach to a distributor while it's spun up to various RPMs. Perhaps even easier than that would be to wire them up to a car. Beware however that many of the old OEM tachs were meant to work with breaker point ignition. Using an electronic ignition as a tach signal is hit or miss - it may work and it may not.
Thread is here:https://www.camaros.net/forums/19-el...chometers.html
Old Nov 14, 2019 | 02:38 PM
Coronet's Avatar
Dash Guage issues
Thank you. May have to put in car to see if it works
Charles
Old Nov 15, 2019 | 09:38 AM
Coronet's Avatar
Dash Guage issues
I think I'll put it in charger to see if they work. Need to make sure voltage limiter is working first. How do I do that?
homebrood
Feb 4, 2013 01:44 PM
rcross
Sep 26, 2010 09:08 AM
flmopars
Aug 26, 2009 07:19 AM
painterlee
Aug 3, 2009 07:21 AM
