Electrical issues after accident help needed multiple things not working right
Old Apr 17, 2018 | 08:16 AM
gwsharklover23's Avatar
1975 Plymouth Duster, was in front passenger collision.
Ever since accident fuel gauge no longer works or reads inaccurate occasionally, windshield wipers intermittently work same for turn signals...
is there something that all 3 are “tied” to? Ground? Fuse? Fusible link?
Any help appreciated, need to find out if all symptoms could be tied together before I start looking into EVERYTHING separately
Old Apr 17, 2018 | 01:23 PM
The only one thing I can think of is the bulkhead connector that has multiple wires running through the firewall. The are known to corrode and fail, a nudge would definitely help it to fail.
Old Apr 17, 2018 | 04:59 PM
Thanks! I’ll check it out, somewhere to start at least.
Im assuming it’s probably located somewhere driver under dash side?
Old Apr 18, 2018 | 05:00 AM
By the master cylinder, big square plug lots of wires. Pulling it apart is straight forward to check for corrosion. Search internet and find lots on the subject.
Old Apr 18, 2018 | 12:55 PM
Got it, will try to check later today, thanks again.
barring that I guess I’ll just track all systems
MOroadrunner
Nov 12, 2015 06:46 AM
freightdog319
Aug 5, 2013 07:16 PM
1972GoldDuster
Sep 28, 2010 04:58 AM
trev0006
May 30, 2010 04:00 AM
Moparknighthawk
May 22, 2010 09:10 PM
