Fender mounted turn signals
Old Apr 6, 2014 | 09:22 PM
dsikkema's Avatar
Was thinking of installing a these on my 68 Fury which didn't come with them originally.
Does anyone know how these would wire in? The existing harness does not appear to have any provision to just plug them in after a quick look the other day.
Any help much appreciated.
Old Jun 2, 2014 | 11:27 AM
labradorian70's Avatar
Do you have a wiring diagram for this car?
Your only option is to look at it and find the positive wire and negative wires that feeds each turn signal on the front of the car and tie into those wires. They might be yellow and Tan.
Cheers
Old Jun 2, 2014 | 06:06 PM
Boat Guy's Avatar
Not sure how Dodge did it, but most others wired into the hot lead going to the turn signal (cut the wire and attach the fender mount to complete the circuit). This allowed the fender mount to indicate if the bulb burned out, as it wouldn't have a complete circuit and would not even light.
Old Jun 2, 2014 | 06:35 PM
windsor56's Avatar
I would check a little further my 68 didn't come with them either but I do have the plugin in my harness
Old Jun 2, 2014 | 07:00 PM
They had them in 67 on Polara and Monico's and such.....
Just tie them into the front T/S they will work just fine....
Dont cut the wire if you dont have too... Just make a y-connector to connect it all together.
Old Jun 3, 2014 | 08:11 AM
There may have been actual different turn harnesses in the engine by. Originally they DID "plug in."
I still miss the ones on the hood on my '70. Hell I miss my 70!!! But I can't afford one anymore
Old Jun 3, 2014 | 08:26 AM
I know the Feeling.....
67rockabillydart
Dec 25, 2012 11:18 PM
JP67
Aug 17, 2012 07:34 PM
JP67
May 10, 2012 03:42 PM
67Polara
Jun 8, 2009 05:53 PM
johnnyc
Mar 4, 2008 06:13 AM
