Help!
Old Sep 21, 2014 | 10:49 AM
Roadrunner808's Avatar
Help!
I have a 69 roadrunner I just picked up it has a charging problem the alt. has been replaced the batt is good but I keep blowing voltage regulators. The ballast resistor looks like it has a jumper between posts. Anyone have any ideas?
Old Sep 21, 2014 | 02:06 PM
Drag Pak's Avatar
There are cheap voltage regulators that this is common with.
Old Sep 21, 2014 | 04:03 PM
I replaced the old with new one and I started up and it up and started smoking. It looked ok inside.
Old Sep 21, 2014 | 05:28 PM
What is your running battery voltage? Do you have voltage drop across your chassis to battery ground?
Old Sep 21, 2014 | 06:29 PM
Running voltage is only 12v.
Old Sep 25, 2014 | 05:14 PM
moe7404's Avatar
you DID check grounds, didnt you? have any stock / O.E.M. ground strips been removed and not put back. i got in the rabbet of adding ground straps to voltage reg, E.C.U... once i even grounded the points in the dist, and they lasted much longer.
