ignition timing without ignition timing light?
Someone who can describe how to easily set the ignition without an ignition timing light? This is a Dodge Pioneer with a 318 engine from 1961..
I am grateful for all the answers I get plz!!
found this on a Swedish site: Did you switch, put a test lamp between the + and pin on the distributor and adjust until the light goes out at 10 º.
I do not know which pins on the distributor, which I will put the light on, there's the middle one and then 8 of them to.
Then I'm not sure which one is cylinder 1 to 8, is the cylinder closest the cooler, where you fill the oil that is number one?
Maybe I can take a pic of the motor and someone can tell my which one is the first and so on..
a -
Do what Eric said. Start the car, once warmed up, loosen the distributor bolt and SLOWLY move the distributor back and forth. The engine will start to run rough as you reach the extremes clockwise and counter-clockwise. You want the best (fastest) rpm (or best vacuum). Lock the distributor bolt.
Drive the car (truck) and do some hard accelerations (up hill if possible). If you don't hear any pinging, leave it alone. If you do hear pinging, back off on the timing a little.
This is the cylinder layout.
The firing order is 1 8 4 3 6 5 7 2
a -
thanks.. I'll try this when I got my new universal joints so I can test drive the car then. The firing order, I knew, I have original manual from 1961, but it never explained which was the first cylinder and so on ..
maca
Jul 24, 2014 01:41 AM
my1968
May 29, 2013 05:49 PM
74Runneer
Mar 2, 2013 06:16 AM
Satellite72
Aug 2, 2011 05:26 PM
rcknrolfender79
Apr 19, 2010 02:10 PM
