MSD 6AL on Charger 440 engine
Hi guys,
I was wondering if I buy MSD ignition 6AL and distributor 8546 and connect as they (MSD) suggest, do I need to left Ignition Module and ballast resistor or not?
As I see on MSD connection diagram, I need to connect 6AL on distributor and ignition coil, so what to do with current wires from Ignition module to distributor and ignition coil? I need to leave them or not? What about ballast resistor?
Thanks in advance.
Thanks in advance.
i bought a MSD box it failed i a few mo. so i stay with the chrysler setup. easy to trouble shoot and fix. the only week spot is the ballast resistor. so just carry two extra in the glove box. they are weakest in cold or hot weather
Yes.... The O.E.M. Module and Resister Dose you no good with the 6AL
Only thing you can use is the Ignition keyed Hot fir the 6AL. All the rest you can just tuck away in some split loom.
One other thing..... Dont forget to get a Blaster Coil to go with all that your installing... Just my 2 cents...
69POLARA383
Feb 9, 2014 09:27 AM
moparjohnson123456
Jun 14, 2011 01:28 PM
