My headlights sucks!
Old Aug 25, 2013 | 08:17 PM
josehf34's Avatar
Hi everyone!
When I go out with my 74 Fury in the night I always notice the headlights sucks! Is not so much difference between turn on the headlights or run with them turned off. Since I had the car I never change any component from headlights system.
What could be wrong?
Old Aug 25, 2013 | 09:55 PM
First make sure you have 12 Volts at the headlight.. You can get Sylvania superstar type head lamps-direct replacement may help you some. OR a CIBLE ? headlights with a complete modification of the mounting and wiring Or maybe a HID conversion .
Start modifying the headlight system make sure to use a relay for power
Old Aug 25, 2013 | 10:06 PM
josehf34's Avatar
I'm going to check the 12 Volts source but all the four headlights works but it doesn't make any difference I can see anything I think this could be a problem of the headlights adjustment
Old Aug 26, 2013 | 03:07 AM
Just because the headlights are on, doesn't mean you are getting all 12 volts, they can still turn on with less voltage. If aiming is the issue, have the front of your car ~20' from a wall and turn them on. You should see four spots and they should all be on the same plain, ~24" off the ground IIRC. At least that is how NH inspection is performed from what I remember.
durangogirl
Dec 11, 2012 09:25 AM
440lives
Dec 5, 2009 08:37 PM
cjperry81
Mar 18, 2009 05:23 PM
mahd
Feb 25, 2009 12:02 AM
skymynx
Nov 17, 2008 09:11 AM
