NEED ELECTRICAL HELP anyone near Nashville or middle tn
Need help with 67 satellite lights pulsating.from someone in middle tn area.
No way close to you but have you checked the condition of your bulkhead connections.
Check the charging circuit Make sure you have the braided/cable strap from the engine/trans bolt to the frame also from motor mount to frame
(Post 106540)
If it's just the headlights then you can fire them up with relays using the power straight from the battery.
Clean all the Grounds.
Also Some Time you need to install a ground strap from the regulator to the engine block if the above dose not work. |
