NEED ELECTRICAL HELP anyone near Nashville or middle tn
Old Aug 2, 2013 | 07:25 PM
TRAMO's Avatar
Need help with 67 satellite lights pulsating.from someone in middle tn area.
Old Aug 2, 2013 | 07:42 PM
No way close to you but have you checked the condition of your bulkhead connections.
Old Aug 2, 2013 | 09:32 PM
Check the charging circuit Make sure you have the braided/cable strap from the engine/trans bolt to the frame also from motor mount to frame
TRAMO's Avatar
i did notice that blk p and yellow l melted and fused sometime in past.but they have been bypassed and the rest of the bulkhead looks good. two new alternators and regulators im aboutat wiits end
Old Aug 3, 2013 | 06:37 AM
If it's just the headlights then you can fire them up with relays using the power straight from the battery.
Old Aug 3, 2013 | 07:27 AM
Clean all the Grounds.
Also Some Time you need to install a ground strap from the regulator to the engine block if the above dose not work.
trev0006
Jun 27, 2013 10:12 AM
lwizardl
Jul 9, 2010 11:28 AM
67gtxclone
May 14, 2010 03:24 PM
MReeves
Sep 15, 2009 05:08 PM
mahd
Sep 18, 2008 10:29 AM
