Need help with battery dying
Old Oct 11, 2022 | 02:10 PM
Wateree12's Avatar
I have a 75 d200 with the 318. I put a electric fuel pump on it the other day attached to a switch and since then the battery has died pretty fast with everything off. I put a new battery in but it kept dying so I changed the alternator and it still just cuts off anytime I unhook the battery terminal. Any thoughts?
Old Oct 11, 2022 | 04:53 PM
You have verified the fuel pump shuts off with the ignition?
Old Oct 11, 2022 | 05:01 PM
Wateree12's Avatar
Fuel pump is connected to a switch I make sure is off after the ignition is off.
Old Oct 11, 2022 | 05:02 PM
Wateree12's Avatar
After I jump the truck off it runs for 3 minutes or so and dies and can’t get it to start again due to battery
Old Oct 12, 2022 | 01:30 AM
If the alternator is charging it sounds like the battery died, pull it and have it checked out.
porkygonzales
May 14, 2020 12:37 PM
heminate
May 7, 2017 07:28 PM
kkritsilas
Jul 2, 2013 07:06 PM
Satellite_Guy
Mar 28, 2009 11:36 AM
Satellite_Guy
Sep 9, 2008 07:00 PM
