Need a replacement steering column harness connector
Old Nov 1, 2018 | 01:54 PM
Vitamin C's Avatar
The 8 pin connector is burnt in the middle from the main red power wire and need a replacement set-up. I looked on line for any flat 8 pin connector that can handle 12 awg but no luck.
I don't want to buy the aftermarket turn signal that comes with the wiring harness either.
Any help would be greatly appreciated on where I can buy the male and female connectors with the new pins.
Old Nov 1, 2018 | 02:15 PM
Vitamin C's Avatar
I actually found an 8 pin harness connector that should work, it's made by American Autowire part # 500428
Not the same but it will work if I replace both sides.
Here is the dash harness side.
Old Nov 3, 2018 | 01:39 PM
Vitamin C's Avatar
This is the ignition switch connector that is burnt up and wish they made a replacement one but I have had no luck.
Old Nov 3, 2018 | 03:24 PM
I have just used what ever has been avalible at the time. I like the Standard or the BWD..... As for the Harness Side, I just use whatever makes it works. Bullet connectors from Lawson Products work well for me in the past.
catchmeifyoucan
Jul 22, 2014 06:17 PM
72chargerSE
Jan 22, 2012 01:13 PM
76NY440_nTX
Jun 12, 2011 04:27 AM
DodgeW200
Sep 4, 2010 09:57 AM
64fury
Jul 7, 2008 07:09 PM
