Need a replacement steering column harness connector
The 8 pin connector is burnt in the middle from the main red power wire and need a replacement set-up. I looked on line for any flat 8 pin connector that can handle 12 awg but no luck.
I don't want to buy the aftermarket turn signal that comes with the wiring harness either.
Any help would be greatly appreciated on where I can buy the male and female connectors with the new pins.
I actually found an 8 pin harness connector that should work, it's made by American Autowire part # 500428
Not the same but it will work if I replace both sides.
Here is the dash harness side.
I have just used what ever has been avalible at the time. I like the Standard or the BWD..... As for the Harness Side, I just use whatever makes it works. Bullet connectors from Lawson Products work well for me in the past.
72chargerSE
01-22-2012 01:13 PM
76NY440_nTX
06-12-2011 04:27 AM
