Tach not working after electronic ig install.
Old Nov 11, 2015 | 01:54 PM
MOroadrunner's Avatar
Replaced points with electronic ignition , now tach will not work. Tach is Sun Tach, probably 20 years old. Do I need to install a newer tach?
Old Nov 11, 2015 | 03:34 PM
Green wire still hooked to the - side of the coil and not broken?
Old Nov 11, 2015 | 04:50 PM
Old Nov 11, 2015 | 04:54 PM
Green wire was hooked to + side of coil ever since I have owned the car & it worked great, but I will switch it & see what happens, Thanks
Old Nov 12, 2015 | 06:46 AM
DDodger's Avatar
If this is a Mopar or Pertronix system:
Make sure the coil is actually hooked up correctly. Coil + should go to ignition run, that is, battery, and should have a radio suppression cap
Coil NEG should have the ignition switch wire from the ECU and the tach
If this is an MSD or other capacitive discharge you do NOT hook the tach to the coil
raceware
Sep 2, 2015 05:50 PM
hckrphil
Jun 25, 2015 08:51 PM
68 Sat
Mar 16, 2009 08:13 AM
azzkikr
Feb 21, 2008 04:36 PM
Plyduster318
Sep 22, 2007 05:32 PM
