wiper motor
Old May 27, 2012 | 02:45 PM
67hemidart's Avatar
wiper motor
the wiper motor in the 67 dart will not run so I was looking to see if I could find a replacement on line and that was not happening so looking for some help ? where to send it for repair or where to get a replacement or what to try to fix the motor spins but not with the 12v just by hand ? thank guys !
Old May 27, 2012 | 11:13 PM
mikerp76's Avatar
try to find a shop that rebuilds/ repais starter and alternators. they should be able to fix it for you as long as teh windings didn't get burned up. it may just need new brushes installed
Old May 28, 2012 | 09:13 AM
The first thing is, are you SURE the motor is what is bad? The 2, 3 speed, and variable speed setups are all wired a "little tricky" and use such things as ground leg switching.
I hope you have gone through the steps in the factory shop manual for testing?
Old May 28, 2012 | 03:07 PM
67hemidart's Avatar
I did not check the manual first ! the motor is prob origanal and has not had a inspection sticker since 1984 so I can only assume it last worked around that time. when we had the engine out I cleaned all the connections on the bulkhead block and coated them with deox non conductive grease then when I reinstalled the wiper motor it did not work. so i removed the electric connector and used a test light to check switch operation it was fine ! so I disected the wiper motor (after finding out that they are not available new)ebay $300.00 ouch !!!!! found the brushes were gumed up armature was green cleaned them and reinstalled yea ha works great both speeds
Old May 28, 2012 | 10:07 PM
mikerp76's Avatar
cool happy to hear that you were able to fix it with out any major headaches.
Old May 29, 2012 | 08:32 AM
LOL Money is often a motivator for me!!
Old May 29, 2012 | 09:40 AM
mikerp76's Avatar
i hear you there.
4x4lover
Jun 30, 2009 09:10 PM
dusterdave
Jun 22, 2009 07:30 PM
68satellite
May 18, 2009 06:35 PM
ronroddey
Apr 13, 2009 02:08 AM
DartConvertible
Jan 21, 2009 09:19 PM
