Can door skins be reused ???????????
Old Apr 11, 2015 | 09:18 PM
motasupra's Avatar
Ok just got two new doors for our car but one had bondo under the paint. can I put the door skin from my current door on the other one? one had a bad frame and the other has a bad skin.
Old Apr 12, 2015 | 05:57 AM
I had to think about this for awhile, I suppose you could cut the spot welds on the skins then unfold the skin from the frame then remove. Then reinstall on good frames that have been cleaned up.
Why do you need to change the doors?
Old Apr 12, 2015 | 11:44 AM
motasupra's Avatar
when I was looking at them it looks like the door hangs on the top of the frame and then has all spot welds on the sides and bottom. I will try to put up some pics. So the main question is if i can remove the one with out trashing the skin. there was hardly any rust on the doors just surface that I put the rust gel on after some wire brushing with the grinder and then using the rust primer spray take that rust. no real pitting or bubbling.
Old Apr 17, 2015 | 12:48 PM
I would check with AMD Metals. May be easier to just buy a skin if it is available. I would bet you ruin it Trying to remove it ? maybe not ?
Old Apr 17, 2015 | 05:15 PM
I have to ask why do you need to replace the doors/skins? lets see some pictures. Have the doors have been gutted for racing and skinned with aluminum, then why not replace the center of the door frame that holds the window mechanism? Leave most of the door intact, as is.
Old Dec 22, 2017 | 06:05 PM
Blackbird's Avatar
And if AMD doesnt have them a good sheetmetal fabricator could make new skins
rcknrolfender79
Mar 13, 2013 10:50 PM
SaltyDogsrfr
Jun 6, 2011 05:43 AM
Idrivemopar
Oct 23, 2010 08:58 PM
67 Fury
Jan 7, 2010 10:29 PM
jeffaary
Jul 25, 2008 09:50 PM
