Rear Seat
Old Jun 14, 2013 | 12:38 PM
kildump's Avatar
Rear Seat
My 67 Coronet 440 has a rear seat installed but I am not sure if it is the correct seat or not. It has the plastic piece installed in the upper half in the center for speakers. I am not too concerned about this seat being the correct one or not. Can someone tell me how to remove both the upper and lower rear seat?
Thanks,
John
Old Jun 15, 2013 | 08:28 PM
mikerp76's Avatar
the lower seat would be held in by a couple of nuts at the bottom front or just clips in to place. then once the bottom is removed the back is then unbolted.
Old Jun 20, 2013 | 11:38 PM
Kern Dog's Avatar
In some cases, the upper section of the seats is held in by straps that were welded to the floor pan. Pretty weird. Most A body car seats were held in with bolts
Old Jun 21, 2013 | 12:04 AM
Bottom of the seat can be removed by pushing the very bottom in and pulling up. (both sides) Then you can remove the top. Will have either twist tabs or bolts at the bottom.
IT sounds like you have a Plymouth rear seat ???? instead of the Coronet one
Rumblefish318
Jul 27, 2013 09:07 PM
MoparOnly
Sep 6, 2010 03:19 PM
c011699
Feb 15, 2010 04:54 AM
Frank's 69
Apr 23, 2009 02:45 PM
skymynx
Nov 30, 2008 03:17 PM
