Restoring Chrome on my Rallye Dash
Part 1 of 3 - Step by Step ReChroming Magnum XE/GT and/or Cordoba air vents. :dance:
Three posts of 25 pics/steps using "Bare Metal foil" http://moparfan.com/userimages/album...after_-_02.jpg Long story short: First you need to carefully remove the vents by removing the dash pad. They are screwed into the back of the dash pad. Using a flat screwdriver through the front of the vent pop the bottom and top pivots and push back and they will come out. The frame piece in the vent in the back will easily come out. http://moparfan.com/userimages/album...10021/0001.jpg To remove the shutters simply pry one side in to get them out. http://moparfan.com/userimages/album...1/0002%7E0.jpg It will fall apart into separate pieces, Very important -now wash everything with soap & water. http://moparfan.com/userimages/album...10021/0003.jpg Note: You could try this with out taking the vent completely apart. It's very hard to get it back together if you've never done it before. Let all the pieces dry, I scrape the old Chrome off with a sharp razerblade. http://moparfan.com/userimages/album...1/0004%7E0.jpg The razerblade leaves it smooth and clean. http://moparfan.com/userimages/album...10021/0005.jpg Size the piece on the Bare-Metal sheet and cut to size leaving a little over hang to make it easier to trim. http://moparfan.com/userimages/album...10021/0006.jpg For this small of a piece I separate the foil from the backing. It's like a very thin tin foil, so be careful not to let it curl up and stick to its self. Save your backing paper! http://moparfan.com/userimages/album...10021/0007.jpg Apply to the vent face using you finger lightly to rub into place. http://moparfan.com/userimages/album...10021/0008.jpg Once it is in place go back over it with your finger a bit harder to make sure its applied to the vent rim. http://moparfan.com/userimages/album...10021/0009.jpg I use the back of my fingernail in pushing and getting out wrinkles in the foil. http://moparfan.com/userimages/album...10021/0010.jpg Continued... |
Part 2 of 3 - Step by Step ReChroming Magnum XE/GT and/or Cordoba air vents. :dance:
Three posts of 25 pics/steps using "Bare Metal foil" Make sure not to fold the foil over the sides, lightly pull the edges out to make it easier to trim. http://moparfan.com/userimages/album...10021/0011.jpg Use a fine point razerknife. http://moparfan.com/userimages/album...10021/0012.jpg Use the tip or smaller part of the knife to trim the inner corners. http://moparfan.com/userimages/album...10021/0013.jpg For the sides cut/trim in a downward motion, so as not to pull up the foil. http://moparfan.com/userimages/album...10021/0014.jpg Once you've cut the inside foil out save it for future projects. http://moparfan.com/userimages/album...10021/0015.jpg Now you know why I said to save the backing paper, re-apply it to the paper. http://moparfan.com/userimages/album...10021/0016.jpg Trim the out side edge the same way, this time you don't need to cut in one piece. http://moparfan.com/userimages/album...10021/0017.jpg You may have some foil on the sides, not a problem! http://moparfan.com/userimages/album...10021/0018.jpg Take your knife and cut or you can lightly scrape the access off. http://moparfan.com/userimages/album...10021/0019.jpg At this point, take a cloth or in my case my shirt and rub/polish the foil to get the chrome look! http://moparfan.com/userimages/album...10021/0020.jpg Continued... |
Part 3 of 3 - Step by Step ReChroming Magnum XE/GT and/or Cordoba air vents. :dance:
Three posts of 25 pics/steps using "Bare Metal foil" OK, now we need to put it all together. For best results put the parts together out side of the vent. http://moparfan.com/userimages/album...10021/0021.jpg Use one of the other vents to make sure you put it together correctly! And it should look like this. http://moparfan.com/userimages/album...10021/0022.jpg Carefully drop the guts back into the back of the vent. Snap in the sides. http://moparfan.com/userimages/album...10021/0023.jpg Re install the frame piece and its ready to be put back in the vent holder. Push it in through the back side while making sure you don't scratch the work you've done! http://moparfan.com/userimages/album...10021/0024.jpg Re install and your DONE! They look NOS new with out the big price tag! An exact match to the factory chrome on my Digital Clock! http://moparfan.com/userimages/album...10021/0025.jpg www.bare-metal.com Ultra-Bright Chrome http://moparfan.com/userimages/album...hrome_foil.jpg Thanks, I hope this helps with the Do-it-your-selfers!! :doh: _________________________________ The End :clap: |
For some reason the drivers vent was not factory chromed? I chromed it too! :clap:
Before: http://moparfan.com/userimages/album...0021/0046b.jpg After: http://moparfan.com/userimages/album...0021/0047b.jpg |
Nice work!
Awesome! This is what I joined a Mopar forum for, not to hear bs about politics or guns.
Originally Posted by Moparod
(Post 100951)
Thanks! |
