318 Holley 4bbl
Old Feb 13, 2013 | 04:59 PM
mopar318's Avatar
318 Holley 4bbl
Im also looking for a Holley 4bbl to go on my 318, wanting the extra pwer from the 4bbl.
Old Feb 13, 2013 | 07:57 PM
Archer's Avatar
318 -
It "might" with the right CFM, but without the right cam and exhaust, the benefits, while real, won't be as great as they could be.
Yes, the tranny's stall converter and rear gears matter too!
Still, for most new hot-rodders, the carb/manifold swap is the first step.
I'd have that tranny /kick-down checked out first though.
Old Feb 16, 2013 | 09:53 AM
When I switched from 2bbl to 4bbl on my 318, I didn’t notice much power gain, honestly. It idled and ran better, for sure, because the carb was brand new, but it sure didn’t thump any harder.
In fact, the biggest “seat of the pants” upgrade I did was replacing the factory fan with an electric unit. Man, that’s a difference!
Old Sep 28, 2021 | 10:42 AM
RockStar1776's Avatar
When you say you put in an electric fan, do you mean the cooling fan on the radiator? I never thought of this as something that would boost power. How would I go about doing that myself? Currently have a belt-driven fan.
Old Sep 28, 2021 | 11:02 AM
Archer's Avatar
RS -
An electric fan doesn't make power, is "saves" power. The HP needed to spin the fan can now go into spinning the wheels.
However, an electric fan will require more output from your alternator (which also uses up more HP) and your wiring has to be up to snuff, if you decide to get a "bigger" alternator.
If you have a clutch fan on there (that works), you might be hard pressed to do that much better.
Old Sep 28, 2021 | 02:06 PM
David Friberger did a episode on Engine Masters, electric and mechanical, he also did a hp loss for running an altters ernator for an electric fan. He came up with the electric fan and alternator took less hp to run than a mechanical fan.
RockStar1776
Sep 28, 2021 10:02 AM
raycan2
Feb 18, 2014 08:13 AM
440-4x4
Aug 14, 2011 04:46 PM
Cazbah362
Jun 12, 2011 01:05 AM
mytracy
Dec 29, 2010 08:20 PM
