89 Dodge Dakota Shelby 318 Fuel sending unit
I am looking for a Sending unit for this truck. No one seems to carry it Dealer ships or parts stores. They only made around 15-1600 of these. Does anyone happen to know a part number or something it would be greatly appreciated.
if you need a pic of what it looks like i can set one up. It has 3 Nipples that stand straight up. and a 5 pin Circle plug in. |
http://i50.tinypic.com/1incc5.jpg
Here is the pic for it. The 45 Degree check valves MAY or may not come with this. under them the nipples are straight. |
I found a part Number on the inside of the neck 4203884. Still no one seems to be able to cross it.
My brother in-law had a 91 (might have been a 93) Dakota with a 318. Perhaps the sending unit is the same? His wasn't a Shelby or anything so the parts should be standard replacement stuff.
your best bet is to find any 87-90 dakota in a junkyard with one. before you get another, make sure the grounds are good.
none of them sending units are the same seems this one was just for the shelby but that seems a little weird to me.
Originally Posted by Xiila
(Post 95314)
you say they arent the same... whats different? |
Lol....
Now i got a new issue, I fixxed the sending unit but now, when i turn the key
It primes it self and i get a little bit of fuel but when i Crank it No fuel what so ever comes out of the supply outlet......Anyone have ANY idea what could be the problem....The Actual pump is New |
First, how did you end up finding a new unit? Second, why did you replace it in the first place?
I didn't
I didn't Replace it i made a easy mod. And the return line Nibble (off the top of the sending use thats broke off in the pic i showed) I was able to get a little larger line on to that broken nipple and then ran the line to the Metal like just Got rid of the 45 Degree angle. And the orig problem was the pump was bad.
Have you checked for voltage at the pump with the key in the "on" position?
Yeh
Yeh i have i get it, Then I get Voltage At the pump when it primes then when i go to crank it the volts drop to 0.2 what ya think the Eng control?
hmmmm.....
Any idea's?
All right Here we go again. Lol, The hall Effect pick up inside the Distrib, is that going to be my Elec control Mod? This dosn't seem to have one, Because with a new coil I aint getting any spark to the Dist.....
