ROSETTE RIVETS NEEDED
Old 08-07-2013, 08:03 PM
TRAMO's Avatar
I am putting back together 70RR my dash has been restored and looks pristeen but i need two rossette rivets to put my vin plate back on.where can they be found at a reasonable price. i know ihave to bite the bullet and buy them but i here you can find them from 10 to 50 dollars.can anyone help me out there.
Old 08-07-2013, 09:45 PM
NOBODY makes them, big legal problems if you do
Old 08-08-2013, 03:37 AM
BuckNeccid's Avatar
You can re-use the originals, if you go to the bottom side of the rivet, use a pair of pliers to squeeze the spread portion together until they can be removed. Take a new 1/8th" rivet and remove the stud from it, and put it thru the removed rosette rivet you intend to re-use. You may have to use a stud to knock out the original popped off ball from the rosette rivet before you can install the new stud. After that point, just use it like a normal pop rivet. MOST times this works, but occasionally, it will not and you may have to take a set of rivets from a junked car. If you have to try a 2nd set, I'd suggest you use some sort of adhesive beneath the VIN plate, just as a secondary attachment, a way to feel more secure in the attachment.
At least this way you can make repairs to VIN mounting surfaces or paint beneath or around the plate without having problems or painting the plate.
Old 08-09-2013, 03:35 PM
TRAMO's Avatar
Restorations by julius" has them $20 a pair shipped.thanx everbody
joe@trimtags.com
06-26-2013 11:54 AM
moparjohnson123456
06-14-2011 01:21 PM
moparjohnson123456
06-13-2011 05:37 PM
ruffinracin121
11-14-2007 12:32 PM
Levit8n
06-29-2007 05:31 AM
Quick Reply: ROSETTE RIVETS NEEDED
