WTB Mopar 383 Cylinder Heads 346, 452,906
Looking for mopar cylinder heads to buy. Looking for a set that is redone and assembled and looking to spend around $450 - $500 shipped. Want something with hardened seats 346 452 or 906 if the seats were added.
(Post 119750)
Hahahahahaha...Lynn..... Mopars are never Cheap..... :)
(Post 119756)
That number looks like a head set.... But you would have to look it up. I'm not sure of the part number....
However My suggestion will be to look at the cooling holes in the gasket and the heads you get and make sure they match....:) |
(Post 119756)
Well I took the heads off today, looks like they put flat top pistons in the block .30. Will the 346 heads still be ok with those.
IF you ARE HAPPY WITH A 8 to 1 cr
You would need to check the deck height of the pistons and figure the compression.....
Going back a few years mid 70's I built a 383 ? may have been a 361 LONG time ago... 12 1/2 TRW forged pistons could not get it to stop pinging had to swap to 906 heads to lower the compression-- it worked !!! |
