1976 Scamp.
1976 Scamp.
The car is a 1976 Scamp 225 slant six located in Western Maryland with 85,094 orig miles, I bought the car last October and put a few thousand miles on it since then.. The car is fun to drive and gets a lot of looks..I put new Plugs, Wires, Air filter and gone through 2 oil changes since then..It has a few patches in the floor from the previous owner..the floor has been under coated and has brand new carpet..all the seats and panels have been removed and re painted..(needs a new passenger side sail panel and could use a new headliner) other than that the inside is CLEAN..I put new Gabriel air shocks in the back about two months ago to give it that classic Mopar stance and re under coated the rear end and underside..The body shows it age with some dents, dings and rust along the 1/4's but i have 2 brand new 1/4 panel skins for that..The rear has been making a noise ever since the previous owner had it..He said it could be a pinion bearing going bad but it doesn't effect how it drives so i never looked into it..I also have a 318 v8 to go with it that i was in the process of rebuilding..The motor is a stock 318 with 360 J heads, New Comp cam and lifter kit, New timing gears and chain, Edelbrock 318 aluminum intake and a Edelbrock 600 carb..Also comes with a 904 transmission and the K member for the V8. Looking to get out what i have into it asking $3,200 OBO..For any question..message me and ill get back to you as soon as i can
76spiritof764speed
Aug 16, 2018 12:12 AM
SKINNY
Feb 9, 2009 03:23 AM
