82 Ram D150 Shortbed , 4-Speed , 318
Old 08-13-2013, 03:12 PM
Mikeman0's Avatar
I haven't had it long , I was going to finish it up in black satin and make a semi-daily toy out of it but im not into it , Fig. id post it up here before it goes on Fleabay , It is driveable but needs a carb cleaning , It is a 82 Dodge Ram 150 Shortbed 2wd , 318 V8 , All new last year == Cam and main bearings , cam and lifter set (lopey) , timing gears and chain , older Edelbrock Alum. intake , Edelbrock 600 carb. (electric choke) , water pump , Headers and duals with Flo-masters dumped , New Dodge performance orange box ignition , New brass cap and rotor , New wires , Factory 4 speed manual , Chrysler 8 1/4 limited slip rear , Power steering and brakes , manual windows and locks , New tires (5000 miles) , All lights work , Heat works , Fresh oil change , new fuel filter , super solid (only rust over drivers rear fender) Clearcoat peeling like all dodges do , $2500.00 , Located in Telford Tn 37690 , Mike 423 557 3632
Attached Thumbnails 82 Ram D150 Shortbed , 4-Speed , 318-029.jpg   82 Ram D150 Shortbed , 4-Speed , 318-036.jpg   82 Ram D150 Shortbed , 4-Speed , 318-033.jpg   82 Ram D150 Shortbed , 4-Speed , 318-032.jpg   82 Ram D150 Shortbed , 4-Speed , 318-039.jpg
82 Ram D150 Shortbed , 4-Speed , 318-046.jpg   82 Ram D150 Shortbed , 4-Speed , 318-047.jpg   82 Ram D150 Shortbed , 4-Speed , 318-054.jpg   82 Ram D150 Shortbed , 4-Speed , 318-052.jpg   82 Ram D150 Shortbed , 4-Speed , 318-053.jpg
Old 08-17-2013, 08:12 PM
Mr.Duster's Avatar
Do you have an email?
Old 08-20-2013, 07:03 AM
Mikeman0's Avatar
Just an update , Carb has been rebuilt and is running a lot better , also just installed a new radiator and thermostat , I will continue to make repairs and adjustments to it and will post up as they are done.
DodgeAddict
08-16-2015 05:23 AM
1Mean318
04-09-2014 07:45 PM
Kevman89
02-26-2014 06:20 PM
Woody194
05-29-2013 02:11 AM
lboggie
08-10-2011 03:23 AM
Quick Reply: 82 Ram D150 Shortbed , 4-Speed , 318
