Dodge Demon 1971 Custom 45 000$
Dodge demon 1971. state of the car, excellent. Condition showroom, Motor magum R/T 360 (5.9 litres) fresh new. Blue printed and full balanced almost 500 hp.
Motor :
-Head edelbrook Magum aluminium Full ported /283cfm @ 0.600 intake
-Valve stainless 2.08in intake / 1.06 exhaust
-Bolts ARP
-Cam MP 292 HR Magnum R/T
-Roller Cam / Roller rocker 1.6 in alliage comp cam
-Piston KB Légé .0220 os Teflon coated (hypereutectic)
-Rode scate I beam
-Harmonic balancer damper with fluide ATI
-Compression 11.0@a
-9000 rpm max but cut off at 8000
-Intake tunnel ram Max-flow ported at port match
-Carburetor Demon 750 CFM double mechanic pompes
-Full kit of poulie in aluminium
-Chromed fuel pump
-Distributor mopar
-Fire Module electronic MSD 6 AL - Coil MSD
-Filage 8.8mm Taylor
-Spark Plugs Autolite
-Tiny starter chrysler high torque
-Step header ceramic coating
-Full exhaust in stainless steel build on mesure.
Other:
-Transmission 727 automatic completely rebuild with torque shift kit ATI of 3000 rpm new
-Every ball joints and tie rod are completely new in polyurethane
-Front and rear brake everything is completely new
-New box steering
-Custom frame connector and torque box in stainless steel polished
-New custom axles bear with gear 3:23 locked and other 3:91 locked for more fun.
-Mag american racing 15”
-Custom t-hand shifter slapstick in stainless steel
-Double electric fan custom
-Complete gaz line in stainless steel ⅜
-Every screw and bolt on the car are in stainless steel polished
-A lot of extra detail but to much to enumerate.
-Powerful sound system with subwoofer of 10”
-Inside finition like new
-Custom suitcase and impeccable
-Body paint polished and body in exceptional condition. This car was restored by professional with the attention to detail.
-The car only have 1000 km traveled
-The car was evaluated 48 000$ by Denis Fausse reputed professional evaluator
-This car is real rare jewelry, a lot of money invested in it.
If interested Contact me on the forum. Thank you
Motor :
-Bolts ARP
-Rode scate I beam
-Compression 11.0@a
-Chromed fuel pump
-Distributor mopar
Other:
-New box steering
eddynugget
08-30-2011 12:37 PM
