1964 Dodge Dart HELP!!!!
Old Mar 20, 2013 | 03:57 PM
1964DodeDartGT's Avatar
Question 1964 Dodge Dart HELP!!!!
I have a 1964 dodge dart GT a-body. it was factory a slant-6 and now been swapped to a 360 from around '74, with a 727 torque flight behind it. i am looking for a 4-speed to match up to it but i do not know what will go on the a-body without modification and hook up to a 360 also. please help me i know its been done, i just need the know how.
Old Mar 20, 2013 | 04:41 PM
jacilynn_s's Avatar
Its been done. You need the 4 speed tunnel welded in to make room for the floor shifter unless you want to go with the column shift. The tunnel is made aftermarket and is not hard to get for the b body cars. Just trim to fit and weld in.
You also need the brackets and pedals for manual. There is plenty of 3 speed manuals for parts.
It's a big job taking quite a bit of time but yes it is doable. Question do you have the pushbutton automatic or did someone put in a column shift transmision and column?
Old Mar 20, 2013 | 05:09 PM
PK1's Avatar
PK1
Although I assume you mean manual transmission, you can also use the 46RH to give you 4 speeds with an automatic.
Old Mar 20, 2013 | 05:13 PM
Gorts 5th's Avatar
Smile
https://moparforums.com/forums/f82/big-time-swap-13473/
It's working fine for me. i recommend it.
Old Mar 20, 2013 | 05:55 PM
Welcome, here are some places with stuff:
http://www.brewersperformance.com/
https://www.passonperformance.com/
Old Mar 21, 2013 | 06:02 AM
The 46RH is not gonna fit an A body without chopping up the floor and crossmemeber
Rogue84
Jan 25, 2015 11:21 AM
Turbotarzan
Jun 30, 2014 06:14 AM
R Nunez
Jan 5, 2014 05:18 PM
motorcitymopar586
Oct 21, 2011 07:44 PM
Joseph A. Stout, Jr.
May 20, 2011 07:23 PM
