Mopar Forums (/forums/)
-   A-Body (https://moparforums.com/forums/f9/)
-   -   727 Tranny Prob's (https://moparforums.com/forums/f9/727-tranny-probs-1293/)
Mixmastermerrill Jul 26, 2008 12:59 AM
727 Tranny Prob's
I have a 727 that barely goes into reverse. All the other gears work just fine. Which band adjustment screw is for the reverse? And when I get to that does the screw need to come in or out? Any other suggestions welcome. And the tranny only has about 5,000 miles on it.
Thanks to all
Doc Jul 26, 2008 02:22 PM
Can you pull-the-pan and test-drive it now?
Mixmastermerrill Jul 27, 2008 03:42 AM
No. The tranny is not in the vehicle just yet.
Doc Jul 27, 2008 05:04 AM
So you can not even pull the pan ?
Mixmastermerrill Jul 27, 2008 05:04 PM
Yes,yes I can pull the pan. But what do I do once I do that.
Doc Jul 27, 2008 05:41 PM
First .... what if anything - other than the ATF ... is in the bottom of the pan ?
Mixmastermerrill Jul 29, 2008 01:18 AM
The only thing in the pan, Clean ATF and a Clean Filter. Nothing seems to be missing or loose.
Any other Ideas would be great
Thanks
richinny Jul 29, 2008 11:19 AM
Thanks to all
can you be more specific? are you talking about the linkage, lever on the transmission case or that when it was in a vehicle, the transmission slipped?
Doc Jul 29, 2008 10:45 PM
Do you see that lever with the nut in the rear of the trans ... from how it rests ... lift up on it .. how far is that?
