8 3/4 gear swap
Old Aug 1, 2008 | 10:28 PM
chlngr1970's Avatar
Good topic. I will be replacing my gears in my Duster soon, and have the same questions. Is an 8.75 housing universal, in that you can change from a '741 to a '742/'489 housing? I guess my other option is to just pick up a new hosing from Mncini Racing
j
Old Aug 2, 2008 | 04:52 PM
chlngr1970's Avatar
Originally Posted by Doc
ALL those housings are diff ... the most popular of the 3 is the 742. And the 742 has also the largest selection of ratios .. the last time I checked.
Sorry to go off topic, but does this mean that I can't put a 742, or a 489 case in my 8 3/4 housing?
j
Old Aug 3, 2008 | 02:39 AM
chlngr1970's Avatar
Well, I have an 8 3/4 Rear End Housing
that has a 741 third member
Will a 742/489 third member fit in any 8 3/4 housing?
Does that make more sence?
j
Old Aug 3, 2008 | 12:37 PM
chlngr1970's Avatar
Great!
It's good to know we are on the same page.
Back to the origional question, If you can make sure all your cllearences are good, then you should be set. If you are not good at rear gear setup, get to an expert...they can save a lot of heartache.
I'm on the lookout for a good grear man here in NW Washington.
j
Old Aug 4, 2008 | 10:13 PM
chlngr1970's Avatar
Yeah, the 742 is the better of the two, congrats. I need to get under my truck to see what it is. Been a long time, but IIRC, it is a feeler gage, like a key ring of different thicknesses of metal, starting at like .005" thick and going to say, .1" thick...
Wow...I didn't think I was that out of it. I found out yesterday that one of my past gurus that I would trust on all things MOPAR passed away, and I find out about it almost 5 months later. Moving half a country away realy takes you out of a scene
j
318scamp
May 2, 2008 03:16 PM
Illstate
Jan 29, 2008 10:37 PM
Brent_72_Cuda
Jan 29, 2008 03:06 PM
gotdust
Jun 28, 2007 10:10 PM
318scamp
Apr 20, 2007 06:35 PM
