a833 sticking
Old Apr 5, 2011 | 04:28 PM
cudaboy68's Avatar
a833 sticking
hello, have a 4 speed in my barracuda,ive changed the selector rods,bushed up the linkages,can a "sticky "or awkard to change gear be a gearbox fault? syncros, detent probs? ive locked the hurst into its neutrals,removed selector rods and put all tabs in middle positions or their neutrals and adjusted rods accordinly,i know reverse has a seperate system to the detent ball etc that the forward gears have should the reverse tab have positive click into a neutral as it seems to be a little free, ie not holding in neutral<with just tab on> like the others many thanks, nathan.
Old May 15, 2011 | 07:27 AM
Snoman's Avatar
Check to make sure your clutch is adjusted right. could be worn syncros if it grinds going into gear, could also be a worn pilot bushing. What is the trans doing exactally?
Old Dec 2, 2012 | 04:23 PM
castillo70's Avatar
pistol grip adjustment trouble
same problem here. i have mocked up the tranny and pistol grip on the bench, i flow nicely 1st and 2nd,nice flow to 3rd and 4th. its really tough going into reverse and almost impossible coming out without an extra hand on the shifter lever.do i need this hooked up to the clutch to flow better. does anybody have any pictures of this linkage attached to the A833,heck maybe i have it hooked up wrong.
Old Dec 2, 2012 | 04:52 PM
Chryco Psycho's Avatar
Mkae sure the reverse lever is center properly , a couple of threads one way or the other can make a huge difference in & out of reverse , also make sure the shifter is clean & lubed it can get very tough to move with 40 yo hardened grease
Old Feb 25, 2013 | 10:03 PM
KCaro81's Avatar
A833 clutch linkage not meshing
I have been having transmission problems as well. You said you replaced the "changed the selector rods,bushed up the linkages," where did you buy these from?
My clutch does not seem to be getting enough travel in the linkages, causing it to ride the release bearing. I have narrowed it down to the clutch linkage and rods, yet I have no idea as to where to purchase new ones.
Any help would be great, I need everything from the clutch rod to the shifter fork rod (i am sure these names for these specific parts are wrong).
Old Feb 26, 2013 | 05:02 AM
bigblock's Avatar
Passon Performance has all your four speed needs. Tell Jamie I sent you. He will also tell you how to fix your 833 over the phone. Phone number is 570-401-8949. Or PASSONPERFORMANCE.com
bully62
Sep 13, 2014 08:00 AM
trivium
May 19, 2011 05:44 AM
jayistcb
Jan 23, 2010 04:08 AM
Jonsalter74
May 13, 2009 03:09 PM
deadkelly
Feb 9, 2009 06:13 PM
