cab for my victor 2 intake
A few other things need to be know to give you an accurate recomendation. Compression ratio, headers/manifolds, exhaust, any work done on the heads, cam? Auto with a converter, or a manual? Gears? With this, we can recommend a good carb for you.
j
j
well i have some 360 heads i bought off a friend i'm not sure it they are though because they were just laying around i also have headers and 3 inch exhaust....just stock cam...i was also wantin to change that too....but i don't really know where to start
Well, here is where I would start. If you stick with the 318, get higher compression pistons. In the 9-9.5:1 ratio. Go with a P4452761 MP cam .450/.455 lift, 268/272 duration. Have the 360 heads rebuilt with a good performance valve job. Ditch the Victor Jr for a Performer RPM Air gap manifold, and a 650 CFM carb. 1 5/8" headers and 2.5" exhaust with good high flowing mufflers. With am Auto, go with a 28-3200 converter, and use 3.23 - 3.55 gears for streatability. 26-28" tall tires, about 8-9" wide for traction.
Hope this helps
j
Hope this helps
j
