Can someone post a enigine bay pic of a 318
Old Nov 24, 2010 | 07:58 PM
mytracy's Avatar
Hey guys so i am goin through my Dart that has a rebuilt 318 and its missing apprently the PVC valve to the driver side valve cover, and its missing the line to the Vacuum advance to the distributor from the carb its a edelbrock 4barrel competition 625CFM carb. can someone post a complete 318 engine so i can see where these lines went to.
or maybe reccomend a site
Thanks
Alex
Old Nov 24, 2010 | 08:28 PM
Frankly, all you need is the destructions for an Edlebrock AFB. The PCV hose goes to the obvious, largest fitting sticking right out the front of the carb.
Here's the manual, right from Edelbrock's site:
http://www.edelbrock.com/automotive_...ers_manual.pdf
Look at the figure down on page 21---the page no's marked in the document, not whatever your reader might say.
You'll have three vacuum ports lined up, when facing the carb, small on left, large in middle, small on right
Far left is "ported" or "timed" vacuum, to the distributor
Middle is PCV (large)
Far right is "full time" vacuum for accessories such as a vacuum operated AC control, etc
Old Nov 24, 2010 | 09:53 PM
mytracy's Avatar
Thanks man!
Old Nov 24, 2010 | 11:08 PM
Originally Posted by mytracy
Thanks man!
Yer welcome. I'm hopin' to get my feet wet after a number of years. I used to run an AFB (then Carter) on a 340, then 318/ 340 top end in my ugly old Landcruiser, has not run in years. I'm contemplating dumping that engine after a minor refresh into my just--acquired 273 Dart.
It'll be a driver, no fancy show car. I have a lot of work---snow is upon us, and now inside shop. I just junked out a 73 Duster for disc front brakes, and a larger 8 1/4 rear.
I'm too lame, now, to row a 4 speed, so this means learning to rebuild a Torqueflite.
But the point is----I just scored TWO really nice Edelbrocks and the "strip kit", so I'm hoping to continue the effort of running one of these AFB's.
Old Nov 25, 2010 | 07:48 AM
mytracy's Avatar
Nice dude!
thats the rear end i am goin to put in too, i have that tiny rear end it might snap after a while with what mods im goin to do to the motor
Old Nov 25, 2010 | 11:31 AM
blue 68 gts's Avatar
Nice dude!
I'd recommend doing an 8 3/4 over the 8 1/4. Both are good rear ends, I find 8 3/4s ALOT more durable, and 8 1/4s are LBP. So to make it right you need to make the front LBP as well.
Just my 2 cents..
Old Dec 26, 2010 | 09:27 PM
twalace's Avatar
If you look at my photo album you will see a pic of a 318 in my dart, had to get a PCV valve & grommet myself and hook it up. Would suggest you check the Edelbrock brochure online for the correct side of the carb to connect your vacuum advance as it depends on your application; smog stuff, etc...
Old Dec 27, 2010 | 09:42 AM
mytracy's Avatar
Thanks man i actually figured it out, it now has the correct gromet size for the valve cover, it did take time like a wild goose chase
gene1970cuda
Non-Mopar Tech Questions
Apr 7, 2015 03:16 AM
deadkelly
Oct 10, 2008 04:12 PM
grahamrw2
Jan 16, 2008 03:52 PM
rampage_82
Dec 7, 2007 08:22 AM
BigBlocksNHardRock
Apr 25, 2007 10:07 PM
