Grinding Noise From Heater Fan ?
Guest
Posts: n/a
Hi Every one I started up my car today (60 Dart 318) and turned on the heater only to hear a grinding noise? Was wondering what it is. Also I get a bit of Brown smoke in exhaust when hard acceleration happens? Thanks on Adv
JLanzino
JLanzino
The smoke and grinding noise are obviously not related. First the grinding noise, There is **** in your blower motor. Could be just leaves and debris or could be a mouse nest. Just clean it out and you'll be fine. Likely not a bad fan motor.
Second the smoke, I guessing the rings are not sealing. Drive it a little and see if it clears up. If the smoke is bad or gets worse, STOP.
