Mopar Forums (/forums/)
-   A-Body (https://moparforums.com/forums/f9/)
-   -   help with swapping auto for 4sp tranny... (https://moparforums.com/forums/f9/help-swapping-auto-4sp-tranny-2716/)
bighammer Apr 6, 2009 04:26 PM
I would like to do the swap someday; has anybody here done this? (auto to manual tranny swap) I located an A-body pedal kit, don't know what it came off of (are all A-body parts interchangeable?)
My Dart is a '70 Swinger w/ a 318 column shift auto. What year tranny's will work for me? I would like to start looking for one. Did the early Darts have the same 4sp as my 70? Will I need to canibalize any other parts of a donar car? Will the bell housing match up? What about the cross member / mount? Will my Dart have the right mounting stuff under there to install the pedal kit?
Thanks for the help!!:D
Mark
johnthegoalie Apr 6, 2009 05:07 PM
for a big block, but it goes over all the work needed. relatively easy swap if you have all the parts, took me a weekend...
http://www.bigblockdart.com/techpages/4sptech.shtml
bighammer Apr 10, 2009 06:43 PM
JTG,
This seems like a bit more of a project than I am willing to undertake at this time! Thanks for the link tho. Good info there.
I think I will stay with my auto trans. Maybe a floor shifter someday ( B&M ratchet ) and I like the bench seat. My sweetie can sit a little closer than she could with buckets...
Any thoughts as to a bench seat with a floor shifter? I know the factory had optional 4 speed with bench seat combo. Dunno/?
Mark
johnthegoalie Apr 10, 2009 11:05 PM
when i was rocking the auto and bench seat, i used a b&m quicksilver. on that one the stick only moves an inch or 2 which helps with the tight clearances.
