Oil leak fixx
Old Oct 18, 2008 | 07:42 PM
Commando's Avatar
Can you get some sort of historic plates in AZ? In NJ I have my car registered as a historic vehicle and then there are no inspections. When I first got my car inspected it passed everything but in NJ you need to have cats, sometimes you can get around that depending on the year. If it was supposed to run on leaded gas it does not need cats, atleast thats what it is here.
Which bolt are you referring to on the pump? There are ones that hold the cover on and the others hold it to the block.
Old Oct 22, 2008 | 03:38 PM
ef8340's Avatar
Senior Member
hi ply
with your car being a 74 ? right you wont need cats they didnt come that way from the factory cats didnt come out until late 75 on cars and 80 on trucks thats why dodge got away with the LRT trucks and other neat ones you should be fine on the cat problem as for your oil leak sounds like your oil filter adapter which angles the oil filter is leaking there is a gasket and if i remember right a o-ring that goes around the bolt they should carry the gaskets at any parts store if not go to a dodge dealer it'll be pricey but it will fix it all that bolt does is hold that piece yor oil filter attaches to all of your a-bodys had them
goodluck
Terry
Old Oct 22, 2008 | 09:53 PM
mr340's Avatar
EF8340 is correct about the leak, there is a gasket on the adapter, and another one on the bolt just under the head. Replace BOTH gaskets and use a thread locker (Loc-tite) on the bolt or you will be doing this again in about 3 hours. (don't ask me how I know, just be happy that I do....)
Skynyrd
Sep 10, 2014 05:24 PM
dzltd02
Oct 28, 2008 08:25 AM
oilplanet
Mar 29, 2008 11:08 AM
robertoil
Jan 25, 2008 05:34 PM
