Orange ECU box with MSD Blaster 2 bad?
Old May 28, 2009 | 05:36 AM
I had an orange box in my 78 D200 with a MSD Blaster 2 coil and never had any problems. I also ran champion plugs and 8mm wires.
Old May 28, 2009 | 08:18 AM
Crazy4Carz.Com's Avatar
Agreed, just don't forget the ballast resistor.
Old May 29, 2009 | 03:53 AM
http://store.summitracing.com/partde...0&autoview=sku
This is the one that I got from Summit Racing. It has a .700 Ohm resistor.
Old Jun 2, 2009 | 08:58 PM
1 Bad Mirada's Avatar
Administrator
ive also heard that you cant run certain MSD parts with certain "stockish" parts..but i dont know of anyone who has actually had a problem with the combo.
Old Jun 3, 2009 | 01:51 AM
You mean like a controller? I have an MSD 5900 ignition box and blaster two coil that I am thinking about installing in my Valaint with a slant 6.
Old Jun 3, 2009 | 06:33 AM
Administrator
maybe it was with the magnum rams...if you used the MSD box you had to also use a certain MSD coil or it was causing computer issues or something...
Old Jun 3, 2009 | 07:06 AM
I have run MSD coils on my 2000 and 2001 Dakota's with 3.9L motors and had a friend run on on his 5.2L in a 98 Ram. never had an issue, of course we were also running 8mm wire. I'm not sure if running stock 6mm-7mm wires would have that much effect on it.
It could be wiring in an ignition box on a magnum motor though.
djmaster219
Mar 2, 2014 07:19 PM
66belvkm
Jun 29, 2013 07:04 PM
440GTXguy
Apr 20, 2013 10:14 PM
DustinHeck
Sep 16, 2012 04:09 PM
Tiretrack
Jul 10, 2010 08:14 PM
