Slant six engine paint?
Hi there
Couple of questions:
1. What is the paint code for the red-orangy 170ci engine paint and where to get/order?
2. Would you recommend an electric fuel pump or stay with the original mech pump? The engine is stock standard 170ci and is currently using "Mitsubishi" electric tick-tick fuel pump (the mech pump is not working).
Thanx for all the help guys.
Cheers
Syed
Cheers
Syed
As for the paint code, I can not help you out there.
For the fuel pump, you should run a mechanical. You can run an electric pump but need to run an adjustable regulator between it and the carb.
Well.......
I know this may not help, because your motor goes red, not orange. But I painted my motor CHEVY orange.
Alot easier to come by + i find it looks better.
I suggest finding a some what dark red, like CHEVY red?
pumps.....
Speaking of pumps....
My 67 dart (/6, 170) has an electric pump, added by previous owner. Thing is really loud at times, rattling thru the entire frame. I just today discovered a pinhole leak in the fuel line from pump to filter, so I'm gonna replace the whole line cause it's rusty and crusty. While i'm it, i was debating replacing the pump with a quieter one. But since 67's didn't come with mechanical ones, I don't know what type or size to get. Any recommendations on a quiet pump that would work for the slant 6? Or would it make more sense to just go back to a mechanical?
And last question, can i replace the steel line from pump to filter with hose, or should I stick with steel?
Thanks in advance
sd
Thanks in advance
sd
Thanks in advance
sd
Thanks in advance
sd
slant6inva
Mar 17, 2013 07:09 AM
