wheels and tires.
Old Dec 20, 2009 | 10:19 PM
thedusterridesagain's Avatar
wheels and tires.
ok so 74 duster with 8 3/4 rear. will a 275 tire work on the back with stock backspacing. im thinkin a 275/60/15. i dont believe there will be clearence issues cause i have a 255 on it now with a decent amount of room but would just like to know. thanks.
Old Dec 21, 2009 | 05:08 AM
3forty's Avatar
Junior Member
What 8 3/4 do you have,A body?,B body?, what rear brakes?, small or large bolt pattern,all this info is important on using 275/60-15 on the rear.
Old Dec 21, 2009 | 02:21 PM
its an a body 8 3/4 . 489 case 3.55 gears. ssbc rear discs. smallest rim that will fit with the kit is a 14 so im good there. also its the large bolt pattern 5x4.5.
Old Dec 21, 2009 | 03:38 PM
3forty's Avatar
Junior Member
[quote=thedusterridesagain;34769]its an a body 8 3/4 . 489 case 3.55 gears. ssbc rear discs. smallest rim that will fit with the kit is a 14 so im good there. also its the large bolt pattern 5x4.5.[/quo
Should be no problems to run a set of 15x8 rims with 4 1/2 inch backspace and 275/60-15 tires. Thats what i ran on my '71 duster with big bolt axles and the large 10 inch brakes,had 1/2 inch clearance at least from sidewall to leaf spring. I have since moved up to 10 inch rims with 275/60-15 tires,tight fit.
Old Dec 21, 2009 | 04:04 PM
thanks alot.
Leem
Mar 26, 2012 02:46 AM
mytracy
Apr 19, 2011 06:15 PM
dhetticher
Mar 12, 2011 09:21 PM
72sat
May 13, 2009 07:46 PM
mcwulf30
Apr 25, 2007 02:38 AM
