Satellite Tires and wheels
Old Jan 29, 2009 | 07:20 PM
72sat's Avatar
This is probably an age old question but with the cost of wheels and tires i want to do this right. I'm looking to replace my tires and wheels and want to go with the old school muscle car stance. I have made my measurements and decided to go with 275/60r15's w/10" rims on the rear with a 5 1/2" backspace. On the front I plan to go with 235/60r15 w/7" rim with stock backspace. I know the 10 " rim will make the 275/60R15 balloon a little due to 1/2" wider recomendation for this tire, but I want that wider look yet to. Has anyone went with this setup and did it work out ok?? Tire rubbing issues?? Unless I missed something with my measurements this should work ok.......I just want cross my T's and dot my I's before I spend the money and achieve the overall look I was after.
Old Feb 25, 2009 | 12:09 PM
72RDRNR's Avatar
I'm a little late to respond to this post but thought I would just incase you still haven't decided on wheels/tires. For my '72 RR I went with 17" all around and also did 275 in rear. No problems...yet. I think I have a 9" rim and 6" Backspacing?? out back and up front it was 8" rim 5" BS and 245 tire. So Iwould think you should be Ok with what you are looking at. If you really want to know what I did I can either dig out the paperwork or measure them. I ended up with Torque Thrust M's (Black). So it still has that old school look with a little update on size. I hope to get some pictures posted soon.
Old Feb 26, 2009 | 07:16 PM
72sat's Avatar
Thanks for the reply....I had a setback financially so the wheels and tires was put on hold. I also decided to rebuild the steering and suspesion prior to wheels and tires ( its a garage project and not my daily driver). I was considering 17" wheels for a more modern look and also hopes of better handling. I would be interested to see how your car looks with the 17's....I had trouble picturing it. I was also thinking about the torque thrust wheels because I like the old school look. If you have time I would be interested in your wheel and tire specs.... but no hurry my car is a working progress. Again, thanks for the input........
Old Feb 27, 2009 | 12:47 PM
72RDRNR's Avatar
I'll see what I can dig up for the paper work this weekend. I am planning on getting it out and working on it next weekend so I will take some pics and measure if I can't find receipts.
Old Mar 22, 2009 | 10:54 AM
72sat's Avatar
72RDRNR, any luck on wheel specs? Also interested in some pics to see how your car sits with the 17's..........Thanks
Old Mar 22, 2009 | 04:49 PM
mopar nate's Avatar
i have a 72 sat if you go on jegs the 342 soft black 8's look great also have a tons other great rims very inexpensive
Old Mar 22, 2009 | 05:54 PM
72sat's Avatar
Thanks for the info mopar nate.........I'll check it out.
Old Mar 24, 2009 | 05:37 AM
72RDRNR's Avatar
Sorry for the delays, the weather was bad so no pix yet but will get soon. The car is burried in garage for winter, so need nice day to clean garage and get it out. I did dig up sizing though...I have:
Front - 17x8--4.5" backspacing 0.0 offset with 245/45 tires
Back - 17x9--5.0" Backspacing 0.0 ofset with 275/40 tires.
Old Mar 25, 2009 | 05:36 PM
72sat's Avatar
Thanks for the specs!!!! I understand on the winter thing, I have'nt hardly touched mine.........I was curious if you noticed a difference in handling going to a 17" wheel? Maybe less flex in tire sidewall.....and if the ride was rougher.........Thanks again for the info
Old Mar 25, 2009 | 06:12 PM
72RDRNR's Avatar
[quote=72sat;16109]I was curious if you noticed a difference in handling going to a 17" wheel? ]
I put them on as it was coming out of 9 yr hibernation. But the way I remember the ride, it is much better now. Used to have air shocks all the up to make room for 50 series M/T's (old school look). One of the shocks was no longer holding air so they were replaced with KYB's all around.
Old Mar 26, 2009 | 06:48 PM
72sat's Avatar
I thought they might........I just wasnt sure if it was going to be all that noticeable. I do believe I'm sold..... I think I will go with newer technology and put 17's on it. Thanks for your input 72RDRNR
Old Apr 1, 2009 | 01:19 PM
72RDRNR's Avatar
I had a hard time finding any info about the larger wheels (as I'm guessing you are) with our cars. Many people are against it and not lots of our style around. I know my Dad was not sold on it until he saw them on and all the compliments it got. Lot's of people are even doing 18's in back and 17's front. I was scared to go too big, so I didn't go that route. But it would give it the higher back end. Mine sits about level, like it would have from factory. I kept it as close to overall tire hight as stock as I could. I might even be half inch less. I am still trying to get it out for pictures (kicking myself for not doing it last fall) but weather is not cooperating with my schedule. What style of wheel are you thinking about?
Old Apr 3, 2009 | 08:26 PM
72sat's Avatar
I'm like you......I like the Torque thrust wheels. Still has the old school look...
Old May 12, 2009 | 08:13 AM
72RDRNR's Avatar
I know its been a long time but I finally got the old bird out and got some pictures!! Sorry the wheels don't show up better, I will try and get some more soon. You can check out my album to see them all.
Attached Thumbnails Satellite Tires and wheels-rr-3.jpg   Satellite Tires and wheels-rr-10.jpg
Old May 13, 2009 | 07:46 PM
72sat's Avatar
Looks good!!!
Leem
Mar 26, 2012 02:46 AM
mytracy
Apr 19, 2011 06:15 PM
dhetticher
Mar 12, 2011 09:21 PM
thedusterridesagain
Dec 21, 2009 04:04 PM
mcwulf30
Apr 25, 2007 02:38 AM
