406 MAGNUM (Small block) CRATE ENGINE — 435 HORSEPOWER
Old Mar 10, 2012 | 08:20 AM
Mopars's Avatar
Paid $9800+ shipping and is brand new!
Open to offers. NO LOWBALLERS!!
This 4.00" stroker engine generates a whopping 435 horsepower and 470 ft.-lbs. of torque, and will quickly make believers out of everyone. It features big valve Magnum R/T cylinder heads and stainless steel valves. Drop one in and let ’er rip. For maximum performance, Mopar recommends the use of a 750 cfm Holley carburetor (P4349228) and 1-7/8" exhaust headers.
Specifications:
• Thermocycled Block Is Bored to +0.020" Oversize
• 4.020" Bore/4.00" Stroke
• 9.0:1 Compression Ratio
• Big Valve Magnum R/T Cylinder Heads
• Distinctive Mopar Cast Aluminum Valve Covers
• 2.02" Intake and 1.625" Exhaust Valves
• Heavy-Duty Valve Springs
• Hydraulic Roller Camshaft — 288ฐ/292ฐ Advertised Duration (230ฐ/234ฐ Duration @ .050") 0.501"/0.513" Lift
• Single Plane, M1ฎ 4-bbl Aluminum Intake Manifold
• (Includes Bosses for MPI Conversion; Taller than Stock — Check Hood Clearance)
• Double Roller Timing Chain and Sprockets
• 8-quart Center Sump Street/Strip Oil Pan
• Mopar Electronic Ignition Kit with Distributor
• Heavy-Duty Engine Stand and Engine Crate
• Does Not Include Accessory Brackets
• Not for Use with A/C or for Factory MPI Installations
• High Volume Oil Pump
• Externally Balanced to Stock (Production) 1993–2003 360 Magnum Engine;
Old May 15, 2013 | 03:10 PM
dodgeboy92's Avatar
I'll give you $20 if you cover shipping. lol
Old May 15, 2013 | 03:51 PM
Whom built it?
pipdog69
Mar 13, 2012 11:01 PM
74bbroadrunner
Mar 13, 2012 08:19 PM
68satellite
May 23, 2009 05:33 AM
Brent1960
May 17, 2009 04:25 PM
mahd
Apr 2, 2009 09:05 AM
