HELP!
Old Feb 20, 2022 | 07:19 PM
Moparbella08's Avatar
HELP!
I have 2020 Dodge Charger with about 13,000 miles on it. I was pulling out of a store parking lot mind you cars was already running and driving. As I’m pulling out of the parking lot out to the main Road (It was dark out) I noticed my dash light up! when I looked down my gauges were moving and all lights on the dashboard were marking as if my car was just Being turn on! Music was still playing and I accelerated a little harder to see if maybe my car with failing or turning off. It wasn’t. I was startled for the rest of the way home about 15-20 mins away. Possible electrical problem.
Old Feb 20, 2022 | 09:40 PM
I would verify that you have a good connection on both ends of the battery cable's. A bad ground will make your dash go crazy...
Old Feb 21, 2022 | 04:26 AM
Archer's Avatar
M -
What Iowan said, or you could have blown a sensor. I had something like that happen to my Challenger a few years back.
Checking for engine codes might tell you what the deal is..
Old Feb 21, 2022 | 07:34 AM
My suggestion is to take it back to the dealer. Should still be under warranty (3 years or 36,000 mile).. Check with them first....
If not? Then I agree with the others... Check the Battery Connections as well as testing the Alternator and Battery.
Khardy
Dec 29, 2021 10:48 AM
BBMopar383
May 4, 2015 05:52 PM
BBMopar383
Apr 1, 2015 06:59 AM
grasoper
Sep 9, 2009 06:52 PM
den2oo278
Mar 4, 2009 09:51 AM
