Oil type????
Old 01-12-2014 | 03:27 PM
Fast4door's Avatar
Question Oil type????
I have a built 318 street car with a huge cam what is the best type and weight oil to use ??? Is a Royal Purple with it??? Should I run 20w50???
Old 01-12-2014 | 06:14 PM
Fast4door's Avatar
No suggestion ?? Or comments????
Old 01-12-2014 | 06:23 PM
OK..I could just be a smart azz......But....
Just ask your engine builder.. He knows all the interals and should be your best bet on a good starting point....
Castrol 5W20 and a bottle of STP would be my first suggestion without know anything of your engine....
moparted's Avatar
brad penn in lightest weight that gives good oil presure
Old 01-13-2014 | 08:09 AM
pro-tech's Avatar
It makes a huge difference on how the engine is built...Flat tappets take different oil then roller tappets / rockers...If you give only half the picture you will get only half an answer..You say it has a huge cam, what is huge to you may be small to someone else..Most of the guys on here are playing for keeps and not even building street cars..So you need to give more info to get the proper answer...I run rotella T 15w40 in my flat tappet 360 with a 474" lift 280* duration cam. I also add zinc to the oil and change it every 1000 to 1500 miles...Bill
Old 01-14-2014 | 03:31 AM
Myraman's Avatar
Rotella 15 40 here too. Many variable as stated above. Good luck
Old 01-28-2014 | 05:43 PM
Fast4door's Avatar
Cam and Lifters, Hydraulic Flat Tappet, Advertised Duration 284/292, Lift .533/.552,
Old 01-28-2014 | 09:21 PM
moe7404's Avatar
things to look at.
1. RPM range
2. bearing clearances
3 lowest air temp it has to be started at
like you are getting tired of hearing from me. do your research. if you do it like chrysler did it you have same out come. chrysler had some race engines in the late 60s., and most if not ALL had a note saying to NOT run the engine at wide open for more than 15 sec.
1968GTX
02-04-2014 07:49 AM
CantRamItDodgeIt91
08-28-2009 09:20 AM
dzltd02
10-28-2008 09:25 AM
robertoil
01-25-2008 06:34 PM
