steering wheel
Old Sep 28, 2024 | 08:58 PM
Zeus_300's Avatar
steering wheel
2013 chrysler 300 v6 steering wheel doesnt have paddle shifters and when i took off the steering wheel and tried to install paddle shifters it didnt have the slots for the paddles to come out and the connection to the original media controls on the back of the steering wheel in only a 2 pin while the new connection is a 3 pin. do i need a whole new steeing wheel with a new connection? do i need a whole new harness
? or can i splice the old one connect new wires and then connect the paddle shifters and then it wouild work? im not sure what to do any help will be grateful?
Old Sep 29, 2024 | 01:28 AM
It’s possible that you will need to change the steering wheel, steering column, some wiring and whatever electronic controller makes the paddles work…
good luck
Old Sep 29, 2024 | 10:58 AM
I am with Iowan on this deal.... Don't know a lot about it.... But you mite check over here if you haven't already? https://www.300cforums.com/
I think if i remember correctly, you posted that you got a new wheel and removed the old wheel and non of the wiring matched up?
If you haven't got both wiring diagrams and studied them? you may find at this point that it may require a bit more than just a bolt on...
Hope you find the answer and report back so we all know the answer !!!!! Cheers... And thanks for being here !!!!
Zeus
Jul 7, 2024 06:51 PM
W250
Nov 26, 2018 05:11 PM
jimiheadstone
Nov 12, 2013 07:53 PM
inri
Jun 19, 2013 10:52 AM
lgad
Apr 20, 2011 03:33 AM
