1972 Charger - From Windsor, Ont.
Old 02-08-2014 | 01:27 PM
Kevman89's Avatar
1972 Viper Charger
Here it is ladies and gentlemen, 1972 Charger, Premium optioned, 29,293 original miles. Originally a 400ci 2 bbl, console shifter car, with black buckets.
So, I have since brought it home from Mount Clemens Michigan, stripped it down, and have my bearings set to where I want to be, and when (Deadlines make me work harder)
I have all kinds of free time (Single, no kids, live at home), and have access to a gigantic variety of tools (Which I've purchased over 10 years), the only issue being... Financial..
So, Here it is when I bought it, imagine 3' of snow..
When I got it home
Cleaned out the left over sand from previous owner getting it sand blasted.. I was worried the barn cats would leave me.... Presents..
Removing bondo/Fiberglass/paint/primer from drivers quarter, also to see what I had to deal with, had some spots that sounded.. Thick when I was looking at it, thank god it was solid.
And as of 45 minutes ago, glass is out, body panels are off, time to start removing the rest of the paint..
Old 02-11-2014 | 10:14 AM
DanK's Avatar
Oh boy. I love the car, can't wait to see what you accomplish. Keep us updated, I'll be watching this one for sure!
Old 02-11-2014 | 10:42 AM
Fun Project...
Old 02-11-2014 | 12:56 PM
moe7404's Avatar
is it time for a flame job? i hope so.
Old 02-11-2014 | 01:13 PM
Buffalojoe426's Avatar
Looks solid! Keep the updates coming!
Old 02-11-2014 | 01:34 PM
Kevman89's Avatar
After doing some careful measurements, and the jaw dropping cost of a TKO 600 swap into this car, we've decided on a new engine, we're going to grab a Gen II or III Viper V10, it should fit with modification to the K-member (Tubular), and moving the rad cradle forward three inches..
Old 02-12-2014 | 05:31 AM
kent's Avatar
Wow she really is in nice shape Kevin. I think I might of made that comment to you on another site we frequent. Nice job man!
Old 02-17-2014 | 12:01 PM
Kevman89's Avatar
At this point.. I have the engine bay almost stripped down to nothing.. Renting a 3500 PSi pressure washer on the nearest warm day (47* F) to power wash off the air craft stripper and the undercoating in the wheel wells..
Here's pics from a few days ago, much further now..
Old 03-01-2014 | 09:58 AM
Kevman89's Avatar
Had the car blasted (Not the body itself,)
Small pin holes in the floor, door jambs and firewall are clean ( I stripped most of it chemically before)
Found a local guy who is a dealer for Moser in Ontario, he's figuring out a Dana 60 to replace my 8 1/4, 3.54 gear, True Trac, with disk brakes..
Engine? Still waiting to sell the other hot rod before we can buy that.. I ordered SFC's, so I can weld those in while everything is clean.
Old 03-01-2014 | 10:08 AM
Progress....
Old 03-01-2014 | 12:16 PM
Myraman's Avatar
Wow! Dove right in! Great job so far. Look forward to watching this!
Old 03-02-2014 | 07:04 PM
Brings back memories. Looking good! Keep at it!
Old 03-21-2014 | 09:23 AM
Kevman89's Avatar
So here's where I'm at as of last night around 10pm..
Yeah, that's exactly what it looks like infront of the Charger..
It's a Gen 3..
Old 03-21-2014 | 10:15 AM
Engine Check
Trans Check
K-Member Check
Looking Better Check
OMG What have I done Check
Moving on now... Looking great !
Old 03-21-2014 | 12:56 PM
Nice!
Old 04-06-2014 | 08:33 PM
Kevman89's Avatar
Some progress since this point.. Frame connectors are in, Kmember is in the car to test fit engine, trans tunnel is cut, and fits T-56..
Trans cross member (Above, connecting frame rail to frame rail) is finished..
Floor pan is welded in (Then cut to fit the SFC's,) new rocker panel is on, still more welding to do..
Haven't updated much.. In the garage..
Old 04-19-2014 | 10:10 AM
Kevman89's Avatar
Removed the motor mounts from the QA1 K-member, welded in new filler plates where they were.
Had to modify where the shifter came up in the trans tunnel, we had to move the engine back an extra inch, in order to have it sit level. The Oil filter will end up in between the two tubes of the K-member, and the flat oil pan allows lots of room..
If you want to ever put a 8.3 into a late model 71-74 B-body, it's definitely no issue when it comes to real estate, there's still a ton of room for headers, but you have to switch to Rack and Pinion..
Aside from those things, it's a nice little project.
Still have to modify some transmission cross member things.. And move it back at least another inch, but it's the way I want it to sit, anyway..
Old 04-27-2014 | 01:41 PM
Kevman89's Avatar
It's in, under it's own weight, on it's custom motor mounts
Still awaiting an Energy Suspension T-56 Transmission mount, before I can fab up the cross member, it's nice to see progress every now and then..
Wiring harness, and computer have been found, from Arrow Racing in Michigan, so as soon as this baby has the floor/Firewall and engine bay painted, we can start getting her running!
Old 08-30-2014 | 12:29 PM
Kevman89's Avatar
Had to get everything assembled for exhaust... Rough body work is finished, and it's in 2k prime. Some developments..
Hydroboost brakes, Rack and pinion, Viper clutch master cylinder with custom bracket, rebuilt '72 Steering column, 8 3/4 rear end with 489 Case, 3.73 gears and a sure grip.
Picked a colour, 2014 SRT 8 Challenger 'Plum Crazy Pearl'
Size:  48.6 KBName:  10590693_10154488478415459_5991861910012921012_n_zps8ee89e97.jpg
Size:  43.6 KBName:  photo27_zpscabaad15.jpg
Size:  52.1 KBName:  photo18_zps9e209248.jpg
Size:  68.4 KBName:  photo28_zpscdfade06.jpg
Old 09-08-2014 | 08:55 PM
Looking Good !!
Old 09-09-2014 | 01:40 PM
BE careful with the sand blasting, the sand gets everywhere
Old 02-01-2015 | 08:02 AM
Kevman89's Avatar
Wow.. haven't posted here in ages..
Where should I begin?!
Found a set of '72 Ralleye doors in the fall, $650 for the set and they were spectacular.. Had a nice gentleman email me from Chicago with a '72 Ralleye hood.. Went and picked it up last weekend..
Exhaust is done, headers are done.. Steering is figured out, ECU and Harness for the V10 is complete, figured out the fuel system, and the body work is completely done on the quarters, doors, and fenders. So I'm just getting ready to take it all back apart and paint underneath!
Here it is on the wheels, decent ride height so far!
The doors after stripping them
Test fitting panels when I first picked them up.. They have since been repaired.. Poly spray, and finish primed..
Old 02-01-2015 | 02:43 PM
Dam..Thats it??? .....Your not done yet !!!!!!!! Were are all the pictures ???? Your holding out on us? arrant you...
Glad your making headway and things are going the way you want them to go. Cant wait to see more progress.. Thanks for the update...Sounding good...
Old 02-01-2015 | 05:00 PM
  #24
Kevman89's Avatar
Haha! Yeah, I've made a ton of progress since, it's like a bomb went off.. Engine is on the stand.. Car is totally stripped awaiting paint underneath, and my wallet is empty..
Old 02-02-2015 | 09:11 AM
  #25
Ooooooooo... That Empty Wallet is a rough one.... Keep us posted..
Kevman89
02-13-2014 03:31 PM
CzechSix
05-10-2011 02:14 PM
redhearts
05-05-2011 02:05 PM
tiregod
06-26-2010 10:19 PM
snik
09-18-2009 07:40 PM
