Slant 6 to 360 D100 swa.
Old Dec 16, 2018 | 04:48 AM
C.Wiggins's Avatar
So I recently acquired an 88 ramcharger 360, 4x4 that I intended to put on the road, but the title work fell through, so I've decided to donate the motor to my 76 D100 that currently has a slant six, I intend to keep the slant and rebuild it so I don't want to completely change everything in doing this swap. I would like to keep my 3 speed manual transmission in the interest of not working on this thing forever, plus I'm okay with not going fast, I just want to make some noise. Is it as straightforward as finding the right bell housing, motor mounts and a flywheel, or have I completely underestimated the work that I'm in for?
Old Dec 16, 2018 | 01:32 PM
Should be straight forward with no problems. The '88 360 should have carb, '89 360 F.I. making it easiest for you, having both vehicles is a huge bonus.
Old Dec 16, 2018 | 03:29 PM
You will need a small block v8 bellhousing for a 77 and a flywheel/clutch and bellcrank for a 360. The belcranks (6 and v8) are not only differant lengths but different ratios also.
slant6
Mar 2, 2013 06:55 AM
challengerseth
Mar 12, 2012 11:01 PM
SfloreS
Jun 21, 2010 12:08 PM
ariesfs
Dec 31, 2008 03:14 PM
thekinzuakid247
Feb 25, 2007 04:13 PM
