1976 W100 Won't Draw Fuel From Tank
Old 11-10-2015 | 09:04 AM
76_W100's Avatar
I have a 1976 W100 with the in frame plastic gas tank. When I towed it to my house and got it running, it drove. Complete engine rebuild, new mechanical fuel pump, Holley 500CFM with manual choke, new fuel line. Runs perfect off a gas can. Tried priming with fuel into the bowl but still no fuel from tank. Don't get why it drew fuel with the original build but not now. I have not pulled the sending unit yet. Tips, thoughts?
Old 11-10-2015 | 06:36 PM
Kinked the steel line or the hose is no good at the tank sender....
Old 11-10-2015 | 11:08 PM
76_W100's Avatar
I replaced the entire line, nice and smooth corners, no kinks.
Old 11-11-2015 | 05:56 AM
I would try blowing air front to back in the fuel system, is it out of gas?
Old 11-11-2015 | 10:09 AM
DDodger's Avatar
Read the service manual and do the checks on the pump. One important check is the vacuum test. A "new" pump does not mean a "good" pump. You didn't say what engine? But you could even have pushrod issues with a B/RB or a loose / failed pump cam or pump arm on a SB
Suspect a gummed up pump pickup. Make sure the connection hoses are in good shape.
Old 11-11-2015 | 01:56 PM
Must be the pick up in the tank is broken in that case...
Old 11-12-2015 | 05:13 PM
76_W100's Avatar
Sorry y'all it's a 5.2 318 LA. It has about 5 gallons of gas in it. I'm going to pull the sending unit this weekend and see what that looks like.
moe7404
12-02-2013 05:26 AM
psytropic
08-24-2010 05:18 PM
wildbill2009
02-11-2010 04:18 AM
wildbill2009
01-10-2010 05:34 PM
Iskone
09-03-2009 09:22 AM
